make-xx doesn't work (Solved)
ForumsGIMP documentation (read-only) ► make-xx doesn't work (Solved)
Sent: 2010-02-10 23:28:41 UTC (almost 2 years ago)
Hi list
I have updated my copy of Cygwin with some new packages and after a
couple of evenings all "git" and "make" commands works fine --- except
for the "make html-xx" (and perhaps make pdf-xx. Not tried as it did not
worked before the updating either).
When running
$ make html-nn
I get these error messages:
*** Making html for nn ...
I/O error : Attempt to load network entity
http://docbook.sourceforge.net/release/xsl/current/xhtml/chunk.xsl
warning: failed to load external entity
"http://docbook.sourceforge.net/release/xsl/current/xhtml/chunk.xsl"
compilation error: file stylesheets/plainhtml.xsl line 8 element import
xsl:import : unable to load
make: *** [html/nn/index.html] Error 5
So, what am I to do to get this command work?
(make validate-nn returns "nn: no errors").
I am always updating (git pull) my copy of gimp-help-2 before working on it.
Kolbjoern
Gimp-docs mailing list
Gimp-docs@lists.XCF.Berkeley.EDU
Sent: 2010-02-11 18:43:43 UTC (almost 2 years ago)
Sent: 2010-02-11 22:45:45 UTC (almost 2 years ago)
Ulf-D. Ehlert skreiv:
> Kolbjørn Stuestøl (Wednesday, 10. February 2010)
>> Hi list
>> except for the "make html-xx" (and perhaps make pdf-xx. Not tried
>> as it did not worked before the updating either).
>> When running
>> $ make html-nn
>> " compilation error: file stylesheets/plainhtml.xsl line 8 element
>> import xsl:import : unable to load
> It looks like your docbook-xsl package is not properly configured.
> Then xsltproc can't find out where the actual "chunk.xsl" is. So you
> should check your XML catalog(s).
> For example, my docbook-xsl package contains an XML catalog file
> /etc/xml/docbook-xsl.xml (which is referred to by the main XML catalog
> file) with the lines
> systemIdStartString="http://docbook.sourceforge.net/release/xsl/current"
> rewritePrefix="file:///usr/share/xml/docbook/stylesheet/nwalsh/1.75.2"/>
> and
> uriStartString="http://docbook.sourceforge.net/release/xsl/current"
> (I guess the second line is important),
> so xsltproc actually reads
> /usr/share/xml/docbook/stylesheet/nwalsh/1.75.2/xhtml/chunk.xsl
> when importing ".../chunk.xsl" in "stylesheets/plainhtml.xsl line 8".
> HTH
> Ulf
Thank you, Ulf
I think you are leading me on the right path :-)
I have to dig a bit deeper in this material. Finding out where the
different files are stored etc. to set the addresses. I think I have
mashed my Cygwin copy a bit up by partially using automatic setup and
partially done it by hand the Unix way.
I bet there is a solution, I only have to find it.
Kolbjoern
Sent: 2010-02-12 21:43:43 UTC (almost 2 years ago)
Problem solved. The solution showed below.
>>> Hi list
>>> When running
>>> $ make html-nn
>> and
>> HTH
>> Ulf
In case someone else run into the same problem:
I had to write the following lines into the file "etc/xml/catalog" to
get the "make html-xx" work:
This solved the problem.
(The docbook-xsl-1.75.2 was installed by running Cygwin install).
Kolbjoern
Welcome!
Lost password?
Not a member? Sign up!
Random tutorials | Latest tutorials
  1. Creating the Che Guevara Effect Creating the Che Guevara Effect 8
  2. Creating a bloody splatter texture Creating a bloody splatter texture 36
  3. Vexel Simulation on Photos Vexel Simulation on Photos 9
  4. Extreme colors for your photos Extreme colors for your photos 3
Latest comments
But I just have 1 more prob (bear with me) I am really having troub... (1 day ago in [AVATAR] Become a real Na'Vi using GIMP!)
I got it to work :) I had to close the image and restart it. I thin... (1 day ago in Create cool rifts with translucent lights!)
there was a second and 3rd release of 2.6.12. we included the lates... (1 day ago in Last stable 2.6 release: 2.6.12 has arrived)
Poll
Is GIMP an adequate application for you to create printed graphics like flyers, advertisments etc?
View results
Latest forum activities
Your Ad Here
facts & numbers
gimpusers.com RSS feed
48 identi.ca followers
750 Twitter followers
powered by bitfire it services
