Clarification for Main Toolbox window
ForumsGIMP documentation (read-only) ► Clarification for Main Toolbox window
Sent: 2009-06-28 15:08:28 UTC (over 2 years ago)
Working my way through the documentation making changes...
see: http://docs.gimp.org/2.6/en/gimp-concepts-usage.html
The description for the Main toolbox window is as follows:
The Main Toolbox: This is the heart of GIMP. It contains the highest
level menu, plus a set of icon buttons that can be used to select tools,
and more.
The image window contains a menu, the Main Toolbox window does not. I
just want to make certain that I am not missing something here and that
I can change this to read:
The Main Toolbox: This is the heart of GIMP. It contains a set of icon
buttons used to select tools, and more.
Andrew Pitonyak
My Macro Document: http://www.pitonyak.org/AndrewMacro.odt
My Book: http://www.hentzenwerke.com/catalog/oome.htm
Info: http://www.pitonyak.org/oo.php
See Also: http://documentation.openoffice.org/HOW_TO/index.html
Gimp-docs mailing list
Gimp-docs@lists.XCF.Berkeley.EDU
Sent: 2009-06-29 05:23:17 UTC (over 2 years ago)
> and more.
That sounds fine. I think the only tricky part is '... and more'. IMHO
you either say, that you can select tools and explain the 'more part'
afterwards in detail. Or you explain exactly what you/we currently mean
with 'more.
Cheers,
Roman Joost
www: http://www.romanofski.de
email: romanofski@gimp.org
Sent: 2009-06-29 06:54:46 UTC (over 2 years ago)
>> and more.
> with 'more.
> Cheers,
Good point on the "what do we mean with "more". I did not give it a
second thought (because I was so preoccupied with the fact that the menu
no longer exists). I will make this change during the week.
The only "more" that I see is that it allows me to choose the foreground
and background color; I assume that in the documentation I should use
"colour", yes?
Andrew Pitonyak
Sent: 2009-06-29 10:35:35 UTC (over 2 years ago)
Hi Andrew,
You are right.
Don't be surprised by that kind of "errors". GIMP-2.6 Help is an update
of v2.4. Updating is more difficult than writing from draft: we are
accustomed to the text and we can easily miss small (even important!)
changes in it :-(.
Your new vision of the text is a very good thing.
Julien
Sent: 2009-06-29 10:48:54 UTC (over 2 years ago)
> Von: Roman Joost
> That sounds fine.
It does contradict the idea of the images being the most important part of a user's GIMP session, though.
GRATIS für alle GMX-Mitglieder: Die maxdome Movie-FLAT!
Jetzt freischalten unter http://portal.gmx.net/de/go/maxdome01
Welcome!
Lost password?
Not a member? Sign up!
Random tutorials | Latest tutorials
  1. Hot Wallpaper with Flames Hot Wallpaper with Flames 52
  2. Generate a stripe-like texture Generate a stripe-like texture 6
  3. Create a shocking sphere/ball Create a shocking sphere/ball 20
  4. Create futuristic looking tech pattern Create futuristic looking tech pattern 12
Latest comments
But I just have 1 more prob (bear with me) I am really having troub... (2 days ago in [AVATAR] Become a real Na'Vi using GIMP!)
I got it to work :) I had to close the image and restart it. I thin... (2 days ago in Create cool rifts with translucent lights!)
there was a second and 3rd release of 2.6.12. we included the lates... (2 days ago in Last stable 2.6 release: 2.6.12 has arrived)
Poll
Is GIMP an adequate application for you to create printed graphics like flyers, advertisments etc?
Latest forum activities
Your Ad Here
facts & numbers
gimpusers.com RSS feed
48 identi.ca followers
750 Twitter followers
powered by bitfire it services
