gimpusers.com logo
German version English version
Not logged in
Sign up! | Lost password?
Latest discussion
  1. gimp-docs | yesterday 10:55 PM
    a new user perspective
  2. gimp-developer | yesterday 08:04 PM
    scanner support should be File->Acquire
  3. gegl-developer | yesterday 06:24 PM
    babl docs
  4. gimp-docs | yesterday 12:46 PM
    GIMP Manual
  5. gimp-user | yesterday 09:42 AM
    Bug
External news
Poll
How good are you at programming?
OMG, that is nothing for me at all!
I've been coding a little bit but I'm not very fit at it
I'm pretty good at programming and would maybe be able to write a Plug-In for GIMP
I'm very good at programming and I would theoretically be able to hack for the GIMP core
See results
Stats
gimpusers.com RSS feed
GIMP Forums » GIMP documentation
First experience with po's
Jump to message:
  1. First experience with... — julien, 27 Dec 2008 06:34 PM
    1. First experience with... — Ulf-D. Ehlert, 28 Dec 2008 01:33 PM
      1. First experience with... — julien, 28 Dec 2008 06:11 PM
As a registered user, you can subscribe forum threads in order to get notified when replies are posted. Just log in at the right top of the page if you already have an account, otherwise you can register for free.
Permalink:4956670A.4060609@wanadoo.fr
Date:27 Dec 2008 06:34 PM
Subject:First experience with po's
Hi all,
Here is my first experience using po's (po/fr/../doc.po, pot/../doc.pot,
src/../doc.xml). I consider two cases:
A - Translating only:
No change in the help structure; no add, no deletion. Only translation
of the strings.
1- Using the po file is the simplest way.
a/ First update this po to get strings that have changed by using the
following command:
msgmerge -U po/fr/../doc.po
This will add changed strings that are marked with a "Fuzzy" comment.
Edit this updated po files, searching for "Fuzzy".
b/ When your file is OK, validate it with this command (being in the
folder containing doc.po):
msgfmt -c --stat doc.po
This displays possible errors and some stats and generate a doc.mo file
that is of no use here.
c/ make the "svn diff"
2- You may want to work on a xml file rather than on a po:
a/ update the po files you want to use as above
b/ Create the xml files for your language (being in "trunk"):
make -f Makefile.GNU xml-fr for example.
This creates a xml folder in "trunk".
c/ Edit the wanted xml file.
d/ We can't validate xml for the moment. But you can open the file in
a web browser (Firefox) that will detect some errors.
Or copy the file in an old sandbox (before xml2po migration) and run
make validate...:-(
e/ Transform your xml file to po (being in trunk):
xml2po -e -o <path to doc.po> -r <path to your doc.xml> src/../doc.xml
(the english doc.xml).
f/ cut-paste the doc.po file into the po directory.
g/ Goto 1b
B - Updating gimp-help-2
1- Edit the src/../doc.xml file (english). Or edit a xml file in your
language and translate it after.
2- Validate it
3- Transform the updated doc.xml file to doc.pot:
xml2po -e -o doc.pot doc.xml
4- Edit the doc.xml file in your language, validate it
5- goto 1e
You may want to view your xml file in html. Waiting for Ulf's make
html-fr, I use
$yelp file:///home/<user-id>/.../trunk/xml/<LANG>/doc.xml
Unfortunately, images are not displayed by yelp. How to do?
I would be very pleased if you can provide a more simple way to work.
Julien
Gimp-docs mailing list
Gimp-docs@lists.XCF.Berkeley.EDU
↑Back to thread overview
Permalink:200812281334.08685.ude88@web.de
Date:28 Dec 2008 01:33 PM
Hi Julien,
julien (Samstag, 27. Dezember 2008, 18:34):
> pot/../doc.pot, src/../doc.xml). I consider two cases:
> translation of the strings.
> the following command:
Use "make po-fr" or "make po/fr/../doc.po".
> the folder containing doc.po):
Should we really add a make target for checking single po files?
Workaround: "make xml-fr" - it this succeeds, the po file should be ok.
> file that is of no use here.
msgfmt will find only simple errors like missing quote (") characters
etc., but it won't find DocBook errors, which are IMHO more likely.
No! Edit the English xml file src/.../doc.xml.
"make validate" should work now, checking the English xml files.
Then try "make po-fr" and edit po/fr/.../doc.po.
Try "make xml-fr" to create (and thus validate) the French xml file(s).
Or "make xml/fr/.../doc.xml" to create just a single xml file.
"make xml/fr/.../doc.draft" (extension '.draft' insted of '.xml') should
also work and should produce an HTML preview file.
> in a web browser (Firefox) that will detect some errors.
"make xml/fr/.../doc.draft" should work, "make validate" too.
> make validate...:-(
No.
> src/../doc.xml (the english doc.xml).
"make po-fr" or "make po/fr/../doc.po",
"make xml-fr".
> g/ Goto 1b
"Goto" considered harmful... ;-)
Yes.
> your language and translate it after.
No!
> 2- Validate it
"make pot" will create pot/../doc.pot.
No!
> 5- goto 1e
> html-fr
Just try "make html-fr" and report what's going wrong.
> , I use
I guess we can't use yelp. As far as I understand it, yelp will try to
create the HTML manual on-the-fly, so this tool is only useful for
small manuals.
For yelp we would have to create a new "mini" manual.
Translating only:
1. "make po-fr" to be up-to-date
2. edit po/fr/.../doc.po
3. "make xml-fr" or "make xml/fr/.../doc.xml" to check the result
4. "make xml/fr/.../doc.draft" to see an HTML preview
5. "make status-fr" to see which po files have to be edited
[not yet implemented, but I will add this feature today]
Adding/changing English documents:
1. edit src/.../doc.xml
2. "make validate"
Adding/changing French documents:
1. Don't! Just update the respective po files.
Of course there are still bugs and some of the command may fail...
Bye,
Ulf
Permalink:4957B341.3030905@wanadoo.fr
Date:28 Dec 2008 06:11 PM
Oh sorry,
I answered to your first message reading the second one.
I will have a try with all that. If I well understand, I can work on
several files and "make" will treat all of them at the same time.
My question about autogen and configure remains valid.
>> make validate...:-(
> No.
> "make xml-fr".
>> g/ Goto 1b
> Yes.
> No!
>> 2- Validate it
> No!
>> 5- goto 1e
>> html-fr
>> , I use
> small manuals.
> Translating only:
> 2. "make validate"
> Bye,
> Ulf
Adobe® Photoshop® is a registered trademark of Adobe Systems, Inc. Linux is a trademark of Linus Torvalds. Ubuntu and Canonical are registered trademarks of Canonical Ltd. | Clock times are shown as CET / CEST | Imprint / Privacy policy | powered by bitfire it services | sponsored by Hirners Hotel Guide
