Hello all,
I apologize if what I'm asking has been covered, I tried searching the
archives at https://lists.xcf.berkeley.edu/lists/gimp-developer/ but it
seems to be broken.
I am currently writing a game that makes heavy use of (256 color)
palette tricks to implement things like multiple colors for the same
in-game bitmap, player sprite customization etc. Because of this, I
need a lot of palette manipulation functionality, and from what I can
see, Gimp does not currently provide what I need. I wrote a few
external programs that do what I need, but I thought it would be nice if
I could contribute my palette manipulation code to Gimp.
The functionality I implemented because I could not figure out how to do
it in Gimp is:
1) Palette shift: Shift all palette entries over by X, all bitmap data
retains its current color (i.e. their palette index shifts as well)
2) Palette merge: Copy palette entries x thru y of image 1 into range a
thru b of image 2. (In Gimp, this could simply be implemented by
copying a range of palette entries with the mouse and pasting them into
the destination palette)
3) "offlimits" palette sections: if pasting RGB data into a 256 color
image, do not allow it to use indices x-y in the destination image's
palette (used to keep a certain palette section reserved)
Finally, and this is somewhat related to number 2, To create a new
palette in Gimp, I go to palettes and go to "Import", I am then able to
create a gradient palette that takes up X number of colors. The problem
is that if I make one with, say, 64 colors, there is no real way (I have
found) in Gimp to then combine this with another palette...i.e. how
would I combine four 64 entry palettes? This might be a problem where
I'm not RTFM, but if not, it's functionality I would like to add.
Anyway, I'm a solid programmer with over 10 years of C under my belt, so
I'm capable of contributing, but I figured I'd mention what I'm
considering here before delving in. It's possible that the
functionality is already there, or already being developed, or otherwise
isn't worth pursuing.
Thoughts?
John
