autogen.sh on msys
autogen.sh on msys | shaneyfelt@juno.com | 22 Nov 19:58 |
autogen.sh on msys | Michael Schumacher | 22 Nov 20:12 |
autogen.sh on msys | Michael Natterer | 22 Nov 20:59 |
autogen.sh on msys | pvt.benkovsk@pha.pvtnet.cz | 23 Nov 14:11 |
autogen.sh on msys | Sven Neumann | 22 Nov 22:56 |
autogen.sh on msys | shaneyfelt@juno.com | 23 Nov 21:15 |
autogen.sh on msys | shaneyfelt@juno.com | 24 Nov 05:22 |
autogen.sh on msys | shaneyfelt@juno.com | 24 Nov 06:59 |
autogen.sh on msys | Michael Schumacher | 24 Nov 11:03 |
autogen.sh on msys | shaneyfelt@juno.com | 24 Nov 18:15 |
autogen.sh on msys | Michael Schumacher | 24 Nov 18:37 |
autogen.sh on msys | lode.leroy@advalvas.be | 25 Nov 10:26 |
autogen.sh on msys | Sven Neumann | 25 Nov 11:49 |
autogen.sh on msys
Something seems wrong with autogen.sh for gimp It doesn't seem to recognize automake 1.8.3 from mingw.org is newer than 1.6
I think that either the HACKING file should be updated to say what works or at least to say that it doesn't work if the problem isn't fixed.
_-T
$ ./autogen.sh
I am testing that you have the required versions of libtool, autoconf, automake, glib-gettextize and intltoolize. This test is not foolproof, so if anything goes wrong, see the file HACKING for more information...
Looks like Win32, you will need libtool 1.5 or newer.
checking for libtool >= 1.5 ... yes (version 1.5.4)
checking for autoconf >= 2.54 ... yes (version 2.56)
checking for automake >= 1.6 ... expr: syntax error
Too old (found version 1.8.3)!
checking for glib-gettextize >= 2.2.0 ... yes (version 2.4.7)
checking for intltool >= 0.17 ... yes (version 0.27.2)
checking for intltool < 0.28 or > 0.31 ... yes
checking for xsltproc ... yes
Please install/upgrade the missing tools and call me again.
_________________
autogen.sh on msys
It works fine with automake 1.8.5 built from source, so I guess that the problem is somewhere in MinGW's automake.
autogen.sh on msys
What version of GIMP is this?
(assuming this is CVS HEAD, it looks like there is something wrong with "expr" and the test fails because of that, rather than because of too old automake).
What does /bin/sh point to?
--mitch
"shaneyfelt@juno.com" writes:
_-T
$ ./autogen.sh
checking for libtool >= 1.5 ... yes (version 1.5.4) checking for autoconf >= 2.54 ... yes (version 2.56) checking for automake >= 1.6 ... expr: syntax error Too old (found version 1.8.3)!
checking for glib-gettextize >= 2.2.0 ... yes (version 2.4.7) checking for intltool >= 0.17 ... yes (version 0.27.2) checking for intltool < 0.28 or > 0.31 ... yes checking for xsltproc ... yesPlease install/upgrade the missing tools and call me again.
autogen.sh on msys
Is your automake executable versioned? It shouldn't be called automake, but automake-1.8. If that is the case, what is the exact output of 'automake-1.8 --version' ?
autogen.sh on msys
And also, do you run it as
./autogen.sh
or
someshell ./autogen.sh
I got burnt in similar way (in another project) by using sh instead of bash, for example
Edheldil
autogen.sh on msys
To answer all the questions about my environment, etc. (I tried to post this yesterday, but never saw it, so maybe Juno dropped it or something) Here's what I did:
Get and install in this order:
from http://gimp-win.sourceforge.net/stable.html
GIMP
GTK+
from http://mingw.org/download.shtml
MINGW
MSYS
msysDTK
Start Msys and create ~/.profile file with the following contents:
export DEVELOPMENT_DIR="$HOME/src"
export CVSROOT=':pserver:anonymous@anoncvs.gimp.org:/cvs/gnome'
export PATH="$DEVELOPMENT_DIR/bin:$DEVELOPMENT_DIR/lib:$PATH"
export CFLAGS="$CFLAGS -I$DEVELOPMENT_DIR/include"
export CPPFLAGS="$CPPFLAGS -I$DEVELOPMENT_DIR/include"
export LDFLAGS="$LDFLAGS -L$DEVELOPMENT_DIR/lib"
export ALOCAL_FLAGS="$ALOCAL_FLAGS -I $DEVELOPMENT_DIR/share/alocal"
echo Ready to build!
Make a folder called ~/src for development and unzip into the ~/src folder so that the contents fall into the same bin, etc, include, share, contrib, lib,... folders:
msys-libtool-1.5.tar.bz2
msys-automake-1.8.2.tar.bz2
from http://www.gimp.org/~tml/gimp/win32/downloads.html
glib-2.4.7.zip
glib-dev-2.4.7.zip
pkgconfig-0.15.zip
[GNU libiconv] libiconv-1.9.1.bin.woe32.zip
gettext-runtime-0.13.1.zip
gtk+-2.4.13.zip
gtk+-dev-2.4.13.zip
pango-1.4.1.zip
pango-dev-1.4.1.zip
atk-1.6.0.zip
atk-dev-1.6.0.zip
from http://gimp-win.sourceforge.net/stable.html [here] ftp://ftp.arnes.si/software/gimp-win/gimp-dev-2.0.1-20040415.zip
from ftp://ftp.zlatkovic.com/pub/libxml/
libxslt-1.1.12.win32.zip
libxml2-2.6.15.win32.zip
Do the following commands (There is no cvs password)
cd src
cvs login = 1.6 ... expr: syntax error
Instead, maybe expr needs to be updated to version __?
$ automake --version Can't locate Automake/Struct.pm in @INC (@INC contains: /usr/share/automake-1.8 /usr/lib/perl5/5.6.1/msys /usr/lib/perl5/5.6.1 /usr/lib/perl5/site_perl/5.6.1/msys /usr/lib/perl5/site_perl/5.6.1 /usr/lib/perl5/site_perl .) at /home/ted/src/bin/automake line 47. BEGIN failed--compilation aborted at /home/ted/src/bin/automake line 47.
Maybe I need to install something called Struct to perl?
I'm keeping a careful record so I can simplify the instructions as much as possible and post them for others to use. I hope that after I finish this, someone should be able to walk up to a new Windows machine, and get things working right away without any surprises.
_-T
_________________
autogen.sh on msys
Still trying to bring up a development environment on mingw. The problem seems to be automake depending upon Struct.pm but trying to install perl modules fails because it expects ftp to behave, which it doesn't on Windows.
Here was the original problem:
I figure that I need to install something called Struct to perl? I assume it's Class::Struct that I need and not one of Inline::Struct, DynaLib::Struct, Win32::API::Struct, Inline::SLang::Struct, SOAP::Struct, Class::MakeMethods::Template::Struct WDDX::Struct, or some other Struct.
trying:
perl -MCPAN -e 'install Struct'
tries to run ftp, but Windows ftp pops up ftp in another console
window, making it obvious that windows ftp doesn't integrate well
with msys.
What's the simplest workaround?
_________________
autogen.sh on msys
Maybe I need to install something called Struct to perl. I assume it's Class::Struct that I need and not one of Inline::Struct, DynaLib::Struct, Win32::API::Struct, Inline::SLang::Struct, SOAP::Struct, Class::MakeMethods::Template::Struct WDDX::Struct, or some other Struct.
trying:
tries to run ftp, but Windows ftp pops up ftp in another console window
where it's obvious that stdio is not being used.
There are two ftp programs in /bin, one called /bin/ftp and the other /bin/ftp.exe
mv /bin/ftp /bin/ftp.bak
solves that problem, but trying perl -MCPAN produces the following message,
Please, install Net::FTP as soon as possible. CPAN.pm installs it for you
if you just type
install Bundle::libnet
so the following commands seem appropriate: perl -MCPAN -e 'install Bundle::libnet' perl -MCPAN -e 'install Class::Struct'
This gives the following error:
The most recent version "0.63" of the module "Class::Struct" comes with the current version of perl (5.8.5). I'll build that only if you ask for something like force install Class::Struct
Trying perl -MCPAN -e 'force install Class::Struct' gives the same message.
Stuck for the moment. Any ideas? Maybe I don't need this version of automake to build GIMP on mingw? Maybe I should back up and try Cygwin instead?
_________________
autogen.sh on msys
You should build automake 1.8.5 (or a later version) from source. If this works for you, we should require this version on Win32.
autogen.sh on msys
]> $ automake --version
]> Can't locate Automake/Struct.pm in @INC (@INC contains:
]/usr/share/automake-1.8 /usr/lib/perl5/5.6.1/msys /usr/lib/perl5/5.6.1
]> Stuck for the moment. Any ideas? ]> Maybe I don't need this version of automake to build GIMP on mingw?
]You should build automake 1.8.5 (or a later version) from source. ]If this works for you, we should require this version on Win32.
Do you mean 1.8.5 won't depend on perl in the same way? or that doing the build should set up perl get and install modules properly?
I'll try it when I get back to my build machine to see what happens.
Thanks,
_-T
_________________
autogen.sh on msys
]> Can't locate Automake/Struct.pm in @INC (@INC contains: ]/usr/share/automake-1.8 /usr/lib/perl5/5.6.1/msys /usr/lib/perl5/5.6.1]> Stuck for the moment. Any ideas? ]> Maybe I don't need this version of automake to build GIMP on mingw?
Automake/Struct.pm is a perl module provided by automake. This should work, I did this myself, and build GIMP on Win32 almost daily.
BTW, see http://wiki.gimp.org/gimp/HowToCompileGimp/MicrosoftWindows for further advice.
HTH,
autogen.sh on msys
IIRC, autogen checks for versionned automakes and aclocals to see if newer versions are installed in parallel to the non-versionned ones. I think it misses the latest (1.8 and 1.9, and just checks for 1.7 or 1.6)
I modified my autogen.sh to test for newer versions of automake:
echo -n "checking for automake >= $AUTOMAKE_REQUIRED_VERSION ... "
if (automake-1.7 --version) < /dev/null > /dev/null 2>&1; then
AUTOMAKE=automake-1.7
ACLOCAL=aclocal-1.7
elif (automake-1.8 --version) < /dev/null > /dev/null 2>&1; then
AUTOMAKE=automake-1.8
ACLOCAL=aclocal-1.8
elif (automake-1.9 --version) < /dev/null > /dev/null 2>&1; then
AUTOMAKE=automake-1.9
ACLOCAL=aclocal-1.9
elif (automake-1.6 --version) < /dev/null > /dev/null 2>&1; then
AUTOMAKE=automake-1.6
ACLOCAL=aclocal-1.6
else
---------------------------------------------------------------------------------- Plaats je zoekertjes GRATIS op AdValvas Placez votre petite annonce GRATUITEMENT sur AdValvas http://www.advalvas.be
autogen.sh on msys
lode.leroy@advalvas.be writes:
You are using an old autogen.sh then. The CVS version checks for newer versions. I wonder why you would want to use autogen.sh with anything but the CVS version of GIMP.
