Gimp and ICC
Hi
I'v just tried to install icc support for gimp using
gimp-color-manager-0.0.7 from http://www.khk.net/color/gimp.html.
I have liblcms (it is part of the debian system I use).
So after unpacking plugin ./configure failed here:
checking for GTK - version >= 1.2.7... yes
checking for gimptool... no
checking for GIMP - version >= 1.1.22... no
*** The gimptool script installed by GIMP could not be found
*** If GIMP was installed in PREFIX, make sure PREFIX/bin is in
*** your path, or set the GIMPTOOL environment variable to the
*** full path to gimptool.
configure: error: Cannot find GIMP: Is gimptool in path?
Well... there is no gimptool here of course. What can I do to make
./configure pass this?
This plugin is a bit old (2 years?) but would be *very* usefull. It is
almost a must to apply ICC profile to *scanned* images because profiles
returns the true colors for scans. This is really working and saves a
lot of troubles during image retouching.
Or maybe there is another ICC plugin for gimp which I don't know about?
Regards
Piotr L.
