RSS/Atom feed identi.ca Twitter
GIMP Git gimp_too_cursors_get_resource error MacOS
12 of 12 messages available
GIMP Git gimp_too_cursors_get_resource error MacOS Partha Bagchi 07 Jun 15:28
  GIMP Git gimp_too_cursors_get_resource error MacOS Michael Natterer 08 Jun 06:56
   GIMP Git gimp_too_cursors_get_resource error MacOS Partha Bagchi 08 Jun 10:36
    GIMP Git gimp_too_cursors_get_resource error MacOS Michael Natterer 08 Jun 10:42
     GIMP Git gimp_too_cursors_get_resource error MacOS Partha Bagchi 13 Jun 13:42
      GIMP Git gimp_too_cursors_get_resource error MacOS Michael Natterer 13 Jun 16:33
       GIMP Git gimp_too_cursors_get_resource error MacOS Partha Bagchi 13 Jun 16:47
        GIMP Git gimp_too_cursors_get_resource error MacOS Michael Natterer 13 Jun 17:31
         GIMP Git gimp_too_cursors_get_resource error MacOS Michael Natterer 13 Jun 17:33
          GIMP Git gimp_too_cursors_get_resource error MacOS Michael Natterer 13 Jun 17:37
           GIMP Git gimp_too_cursors_get_resource error MacOS Partha Bagchi 13 Jun 17:54
            GIMP Git gimp_too_cursors_get_resource error MacOS Partha Bagchi 14 Jun 03:00
Partha Bagchi
2018-06-07 15:28:19 UTC (4 months ago)
I get the following:
Undefined symbols for architecture x86_64: "_gimp_tool_cursors_get_resource", referenced from: -u command line option
ld: symbol(s) not found for architecture x86_64 clang: error: linker command failed with exit code 1 (use -v to see invocation)
make[3]: *** [gimp-console-2.99] Error 1
This is due to this line in ./app/Makefile
#\ # -Wl,-u,$(SYMPREFIX)gimp_tool_cursors_get_resource
I think this should not be there. After I comment it out, it compiles normally.
Thanks,
Partha
Michael Natterer
2018-06-08 06:56:28 UTC (4 months ago)
But you probably have no cursors :)
The symbol must be there is the resource file was properly generated.
--Mitch
Partha Bagchi
2018-06-08 10:36:05 UTC (4 months ago)
How do I verify that? Wouldn't I have had this issue when I was compiling GIMP 2.10? Little confused. :)
I assume the resource file is ./app/widgets/gimp-tool-cursors.c? This file is identical to GIMP-2.10/cursors/gimp-tool-cursors.c. So, does that mean it was generated properly?
I also noticed that GIMP 2.10 Makfile.am didn't include that line while GIMP 2.99.1 does.
--Mitch
Thanks,
Partha
Michael Natterer
2018-06-08 10:42:25 UTC (4 months ago)
invocation)
normally.
Cursor resource genration was changed in master, we now generate them in the directory where they are compiled , but they have to be linked in by force because nothing in the source references the symbol.
Just check if you tools have different cursors.
GIMP 2.99.1 does.
--Mitch
Thanks,
Partha
Partha Bagchi
2018-06-13 13:42:42 UTC (4 months ago)
invocation)
normally.
Sorry for the late response Mitch. Due to change in the App structure, it
took me a while to create a MacOS app.
Anyway, I'm not exactly sure how to check if the tools have different cursors. Do you mean for instance that If I've selected the lasso tool, then the cursor turns to a lasso? In my case it does.
However, I do have the following message:
gimp_devices_restore: set default tool on loaded GimpDeviceInfo without
tool options: Quartz Cursor
gimp_devices_restore: set default tool on loaded GimpDeviceInfo without tool options: Quartz Eraser
gimp_devices_restore: set default tool on loaded GimpDeviceInfo without tool options: Quartz Pen
There there's more to this?
Thanks, Partha
Michael Natterer
2018-06-13 16:33:23 UTC (4 months ago)
see
invocation)
normally.
Then it's good :)
No this should happen only when reading devicerc that was written by an older version, the messages just indicate that importing the old format worked. Save devices once (or on each exit) and it will be silent.
Mitch
Partha Bagchi
2018-06-13 16:47:52 UTC (4 months ago)
see
invocation)
normally.
Then it's good :)
That's good to know from my perspective too! :)
Then we have to remove Line 134 from ./app/Makefile.am. Otherwise, GIMP won't compile. Do you agree?
Ahh, yes, OK. Since it's reading the devicerc from GIMP 2.10.2.
Mitch
Thanks,
Partha
Michael Natterer
2018-06-13 17:31:22 UTC (4 months ago)
to
see
invocation)
compiles
normally.
compiling
the symbol.
tool,
Then it's good :)
If we remove that line, we don't have cursors at all, it simply won't link in the file that's not referenced from anywhere, on linux, gcc and standard ld.
Regards, Mitch
Michael Natterer
2018-06-13 17:33:51 UTC (4 months ago)
-v
to
see
invocation)
it
compiles
normally.
compiling
the symbol.
tool,
Then it's good :)
Sent too early...
Does the linker error happend for gimp-console or gimp?
Michael Natterer
2018-06-13 17:37:54 UTC (4 months ago)
-v
to
see
invocation)
it
compiles
normally.
was
compiling
the symbol.
tool,
Then it's good :)
GIMP
Sent too early...
Well... git pull :)
Partha Bagchi
2018-06-13 17:54:19 UTC (4 months ago)
-v
to
see
invocation)
it
compiles
normally.
was
compiling
the symbol.
tool,
Then it's good :)
GIMP
Sent too early...
I think gimp-console, but I'll have to check again tonight and will let you know.
Well... git pull :)
Will do. :) Thanks!
Partha Bagchi
2018-06-14 03:00:28 UTC (4 months ago)
-v
to
see
invocation)
it
compiles
normally.
was
compiling
the symbol.
tool,
Then it's good :)
GIMP
Sent too early...
Well... git pull :)
Will do. :) Thanks!
OK! You fixed it! Now it compiles. :)
Thanks!!
