translations
| translations | free | 17 Aug 17:54 |
| translations | Alexandre Prokoudine | 17 Aug 18:00 |
| translations | free | 17 Aug 18:18 |
| translations | Joao S. O. Bueno | 17 Aug 18:26 |
| translations | scl | 19 Aug 07:54 |
| translations | Joao S. O. Bueno | 19 Aug 11:59 |
| translations | Willer Gomes Junior | 19 Aug 15:50 |
| translations | Alexandre Prokoudine | 19 Aug 16:37 |
| translations | Jernej Simončič | 19 Aug 17:34 |
| translations | wanderer | 20 Aug 00:26 |
| translations | Jernej Simončič | 20 Aug 08:29 |
| translations | free | 20 Aug 11:31 |
| translations | Jernej Simončič | 20 Aug 16:25 |
translations
Who are the people responsible for translating gimp? I am a portuguese speaker and I could help translating the installer, the program, documentation... How do I get in contact with them?
Thanks to all,
Thiago Petruccelli
translations
Typically they are people from local GNOME's translation team. Looking up headers of PO files usually helps: http://git.gnome.org/browse/gimp/plain/po/pt.po
Docs are not available in Portuguese yet. There's only initial translation into Brazilian Portuguese. There's gimp-docs@ mailing list.
http://libregraphicsworld.org
translations
Thanks Alexandre. I've sent an e-mail to the translator mentioned in the
link you sent me, and I'll subscribe to the gimp-docs mailing list.
Let's see if I can help with something.
Thiago Henrique Petruccelli
Em 17/8/2012 15:00, Alexandre Prokoudine escreveu:
gimp-developer-list@gnome.org
translations
On 17 August 2012 15:18, free wrote:
Thanks Alexandre. I've sent an e-mail to the translator mentioned in the link you sent me, and I'll subscribe to the gimp-docs mailing list. Let's see if I can help with something
Hi Thiago --
I am the responsible for the translation to Brazilian Portuguese -
and if you want to collaborate with this translation, I'd ask you to write me -
there are other people collaborating.
If you are talking about Portuguese from Portugal or other variantes, contact them on the above mentioned gnome-list.
js
Thiago Henrique PetruccelliEm 17/8/2012 15:00, Alexandre Prokoudine escreveu:
https://mail.gnome.org/mailman/listinfo/gimp-developer-list_______________________________________________ gimp-developer-list mailing list
translations
Hi Thiago,
lately I found http://www.pylyglot.org/. This website compares translations in various free software projects. You can search for a given string and it will tell you how other software projects already translated it. Perhaps it will be a help for you (and other translators). For German readers there's also an article about it at http://linuxundich.de/de/ubuntu/pylyglot-vergleicht-ubersetzungen-in-freier-software/
Kind regards,
translations
I' ve talked to Thiago -
what he found that is not translated to pt_BR in GIMP is
the Windows Installer (the "next,next,finish wizard).
That is not a "gnome project" - do you know where the code for that is hosted, and whether that is even translatable?
js ->
translations
If I understand right, I think you are looking for a software like Weblate
http://weblate.org/en/, seems to be a very good software. I've used recently
as a translator and as a checker. You don't check what you translate. Many
people are needed to approve a text. It takes a certain number of
checks without
corrections to the text being approved. Thus, a set of translations
performed direct the path of translation.
I believe that this may decrease the work of coordination too.
Some groups use this tool in Debian. I am an active member of groups there too, one of them uses Weblate (http://debian.weblate.org/). The only problem is the need to be online during translation.
I intend to continue with the translation of the manual that I started of
the Gimp manual, soon.
Best if it is implemented.
I do not know Weblate right, but it's a tip.
2012/8/19 Joao S. O. Bueno
http://libregraphicsworld.orgI' ve talked to Thiago -
what he found that is not translated to pt_BR in GIMP is the Windows Installer (the "next,next,finish wizard).That is not a "gnome project" - do you know where the code for that is hosted, and whether that is even translatable?
js ->
translations
Of course it's translatable. It's just for some reason we don't keep these file in the source tree (Inkscape does, for example), so translations aren't really available. You'd have to ask ender about that.
translations
Actually, the files are in the source tree, but only in the 2.8 branch:
The messages seen here are specific to the GIMP installer only. Inno Setup has it's own translations, though it already includes Portuguese, so that doesn't have to be translated:
English language file for Inno Setup is available here:
Note that these language files must use the windows ANSI codepage for that language (for most western languages this is cp1252).
translations
Sorry for taking so long to answer.
Thanks for pointing the way for me. I've downloaded the file "en.setup.isl", from where I'll do the translation. The tips on weblate and pylyglot were very useful! I'll start the translation right away.
There's some way for me to "test" how my text will appear on the installer?
Em 19-08-2012 14:34, Jernej Simončič escreveu:
translations
Not easily, but possible: first you'll have to install Inno Setup (Unicode version) from .
Next, check out the entire installer directory from git, and open gimp3264.iss in Inno Setup. Scroll down to the [Languages] section, and add your language there - the line should look something like this:
Name: "pt"; MessagesFile: "compiler:Languages\Portuguese.isl,lang\pt.setup.isl"
(the compiler: prefix means that the main language file will be loaded from Inno Setup's installation directory).
Press F9, and a testing installer will be created and run (the installer won't include any files, but other than that it'll behave identically to the normal installer). Later, if you change the language file, recompile the installer with Ctrl+F9 before running it with F9.
If you notice any problems that you can't fix yourself (eg. string that doesn't fit), notify me, and I'll see if I can adjust the windows.
translations
Thanks Jernej,
I've already finished the translation, so I'll try to do these steps you pointed me to test if characters like ç, ã, etc. are displaying correctly. I'll let you know if something appears that I can't fix.
regards,
Thiago H. Petruccelli
Em 20/8/2012 05:29, Jernej Simončič escreveu:
translations
You can just send me the files (or commit them to git), and I'll prepare an installer (after verifying that the language file is in correct encoding).
1015 @ Twitter
