buildbot failure in GIMP on gimp-distcheck
ForumsFor GIMP developers (read-only) ► buildbot failure in GIMP on gimp-distcheck
Sent: 2010-09-07 07:48:24 UTC (over 1 year ago)
Nightly builds with buildbot, where can we host?
On 09/06/2010 10:02 PM, Sven Neumann wrote:
> On Mon, 2010-09-06 at 21:38 +0200, Martin Nordholts wrote:
>> On 09/06/2010 09:22 PM, Sven Neumann wrote:
>>> Will buildbot build failures be posted to this list? Do you have the
>>> 'blame' feature setup so that the commits that potentially broke the
>>> build are listed?
>> I think posting failures to the list would create too much spam, my plan
>> was to have an IRC bot for that instead.
> Hmm, buildbot has support for that, but I don't quite understand what
> buildbot output on IRC would be good for. IMO the buildbot web-site
> should be accessible by anyone and the bot should send mails in the case
> of a build failure. Given how seldom the GIMP tree does not compile,
> this shouldn't create too much traffic.
Well, mails would not only be sent in case of compile failure but also
in the case of make distcheck failure, which is quite easy to break. But
we can certainly try and see how it plays out.
/ Martin
My GIMP Blog:
http://www.chromecode.com/
"Automatic tab style and removed tab title bar"
Gimp-developer mailing list
Sent: 2010-09-07 18:26:05 UTC (over 1 year ago)
How about letting this buildbot approving commits in some way?
http://wiki.hudson-ci.org/display/HUDSON/Gerrit+Plugin
Emil
>>>> build are listed?
>  / Martin
> My GIMP Blog:
Emil
Sent: 2010-09-07 19:46:29 UTC (over 1 year ago)
On 09/07/2010 06:26 PM, Emil Assarsson wrote:
> Hi,
My employer uses Hudson and I considered using Hudson for GIMP too.
Automatically building and testing commits before they are merged to
master is a really neat thing to do.
But I chose buildbot over Hudson because
* buildbot is more readily available than Hudson, for example, Fedora 13
does not have Hudson packages
* buildbot is built on Python, which is less controversial in terms of
software freedom than Java (Personally I'm fine with both, but it can
still matter to some)
* I already knew Hudson and wanted to learn buildbot
* I feared that people would look at Gerrit+Hudson as an obstacle, since
commits needs to be submitted, it's not enough to just push
And now that I've experimented with buildbot a bit, I have ended up
liking the system, so I don't plan to switch over to Hudson
/ Martin
My GIMP Blog:
Sent: 2010-09-08 07:03:21 UTC (over 1 year ago)
>>>> build are listed?
I have mails being sent on failure now to my own inbox, but the
blamelist doesn't work yet. As soon as it does I'll make the buildbot
(currently hosted on my laptop until we have a proper host) send mails
directly to gimp-developer.
For now I'll just forward failure mails manually.
GIMP make distcheck failed tonight:
make[1]: Entering directory `/var/buildbot-slave/gimp/build'
Problem found in ./libgimp/gimp.def
the following symbols are in the library,
but are not listed in the .def-file:
+ gimp_item_transform_2d
+ gimp_item_transform_flip
+ gimp_item_transform_flip_simple
+ gimp_item_transform_matrix
+ gimp_item_transform_perspective
+ gimp_item_transform_rotate
+ gimp_item_transform_rotate_simple
+ gimp_item_transform_scale
+ gimp_item_transform_shear
*** .def files inconsistent ***
make[1]: *** [check-defs] Error 1
make[1]: Leaving directory `/var/buildbot-slave/gimp/build'
make: *** [distdir] Error 2
/ Martin
My GIMP Blog:
Welcome!
Lost password?
Not a member? Sign up!
Random tutorials | Latest tutorials
  1. Cool glowing text Cool glowing text 40
  2. Creating 3D icons Creating 3D icons 35
  3. Create an amazing electricity effect on any object! Create an amazing electricity effect on any object! 6
  4. Create the Dragan effect Create the Dragan effect 2
Latest comments
But I just have 1 more prob (bear with me) I am really having troub... (2 days ago in [AVATAR] Become a real Na'Vi using GIMP!)
I got it to work :) I had to close the image and restart it. I thin... (2 days ago in Create cool rifts with translucent lights!)
there was a second and 3rd release of 2.6.12. we included the lates... (2 days ago in Last stable 2.6 release: 2.6.12 has arrived)
Poll
Is GIMP an adequate application for you to create printed graphics like flyers, advertisments etc?
View results
Latest forum activities
Your Ad Here
facts & numbers
gimpusers.com RSS feed
48 identi.ca followers
750 Twitter followers
powered by bitfire it services
