Wish: A better animation system inside GIMP
ForumsFor GIMP developers (read-only) ► Wish: A better animation system inside GIMP
Sent: 2010-08-29 09:01:49 UTC (over 1 year ago)
Currently, creating animations in GIMP is not done in a very clean
way. To specify the duration of each frame and to specify whether it
should stay or be hidden after that period, we abuse the layer names.
Until recently we also had a limit of one layer per frame so we
couldn't have had a frame composed out of several layers (so
maintaining the frames had to be done in other files), but now layer
groups can solve this (so the animation process is now a bit better).
I'm posting here a small wishlist regarding using GIMP for animations,
to get the general approval before posting it as an enhancement
request in bugzilla:
* More supported frame disposal modes - GIF has 3 frame disposal
modes (taken from
http://www.webreference.com/content/studio/disposal.html ):
1. "Leave" - after the period of the frame has ended, the frame's
pixels will remain visible and the next frames will be displayed on
top of it. This mode IS supported in GIMP.
2. "Restore Previous" - after the period of the frame has ended, the
frame's pixels will become transparent and will allow to see what was
in that region before the current frame covered it. This mode IS
supported in GIMP.
3. "Restore Background" - after the period of the frame has ended, the
rectangle of that frame will be replaced by a transparent rectangle.
It's similar to "Restore Previous", except for the fact that after the
frame disappears you won't be able to see what was below it. This
mode IS NOT supported in GIMP, and this is the mode I want to add.
Supporting this mode means modifying the gif load/save plugin, the
animation preview plugin and possibly the un/optimize plugins.
* A better animation editing modes. Abusing the layer modes is a very
bad way to do this (at least in my opinion) - see a similar case in
https://bugzilla.gnome.org/show_bug.cgi?id=344910 comment 3. We should
remember the animation parameters using parasites, and by having some
animation editor plugin (which leads to my next point - an animation
editor)
* GIMP should have an animation editor which is integrated with a
preview of the animation. Editing the animation and then closing the
editor just to open the preview plugin is a very bad workflow. You
should be able to preview from the same place you edit.
Also, the editor should allow to edit the parasites of the layers
which include the animation parameter.
I have something in mind similar to MS Gif Animator
(http://en.wikipedia.org/wiki/Microsoft_GIF_Animator), or anything
with a similar simple UI.
This is how I imagine the animation workflow with GIMP - I'll
appreciate some feedback.
~LightningIsMyName
Gimp-developer mailing list
Sent: 2010-08-29 09:15:53 UTC (over 1 year ago)
You seem to be interested only in animated GIF?
Even in this case, are you aware of the GIMP Animation Package?
Olivier Lecarme
Sent: 2010-08-29 09:37:30 UTC (over 1 year ago)
Forgot to mention that it would also require to change most animation
scripts and GAP...
> Olivier Lecarme
First of all, yes - I am aware of GAP and I used it several times
(although I'm still not completely familiar with it).
Still, abusing layer names must stop and this is my main request - and
in order to stop this we must introduce a very simple animation editor
(since we have many animation scripts and it should be possible to
edit their result). GAP is very good and complicated, and I'm
referring to something much simpler only to edit the frame
duration/disposal (instead of the ugly layer name hack) - nothing
more.
~LightningIsMyName
Sent: 2010-08-29 10:05:13 UTC (over 1 year ago)
With keyframing, presumably?
Alexandre Prokoudine
http://libregraphicsworld.org
Sent: 2010-08-29 10:37:40 UTC (over 1 year ago)
2010/8/29 LightningIsMyName
> Hello,
> scripts and GAP...
> > Olivier Lecarme
> more.
> GAP is not very complicated, simply it is not well described.
If you are interested in multi-layer animations, the duration and mode of
layers is obviously a layer property. Why not use the layer name for this?
It is available and not very useful for anything else in this precise case.
Olivier Lecarme
Sent: 2010-08-29 19:57:37 UTC (over 1 year ago)
On 08/29/2010 09:01 AM, LightningIsMyName wrote:
> Hello,
> way.
That's not a problem since creating animations is not a defined goal in
the GIMP product vision. I rather think we should remove support for
animations in GIMP for 3.0, plug-ins can supply that functionality instead.
/ Martin
My GIMP Blog:
http://www.chromecode.com/
"Automatic tab style and removed tab title bar"
Sent: 2010-08-30 15:52:02 UTC (over 1 year ago)
Hi guys,
I'm pretty aware that animations are not the goal in GIMP, however,
I'm working in the past five years with GIMP to produce animations.
Anyway, the thing is, I believe that the GIMP-GAP can goes forward and
replace the animation filters completely. The animation filter is a
great light-table tool, is pretty useful and we don't have something
similar in GAP. Is not the right moment to remove or replace the
animations filter, and maybe the right time to notice that the
animation is a real function of GIMP and assume this as part of the
product vision.
Cheers
Daniel Pinheiro Lima
http://blogdooswaldo.blogspot.com/
Sent: 2010-10-04 10:24:24 UTC (over 1 year ago)
in GAP I would like to see
- repaired .APNG support (import and export)
- .MNG (import and export)
- numbered .BMP's as frames (used in a number of video frame conversion
programs) (import and export)
- .AVI (import and export, but you can limit the kinds of video formats you want
to support, since there are MANY)
- .flv (import and export) (I think it already does this)
- .swf (import and export)
and if someone really feels like doing it, .mpg and .vp8 files and some of the
modern formats.  I believe mplayer can read a lot of these formats, and what
mplayer does not read, ffmpeg does. ffmpeg even does AVI[MJPEG] which is what my
camera puts out.
Jim Michaels
jmichae3@yahoo.com
JimM@JimsComputerRepairandWebDesign.com
http://JimsComputerRepairandWebDesign.com
http://JesusnJim.com (my personal site, has software)
http://DoLifeComputers.JesusnJim.com (group which I lead)
Computer memory/disk size measurements:
[KB KiB] [MB MiB] [GB GiB] [TB TiB]
[10^3B=1000B=1KB][10^6B=1000000B=1MB][10^9B=1000000000B=1GB][10^12B=1000000000000B=1TB]
[2^10B=1024B=1KiB][2^20B=1048576B=1MiB][2^30B=1073741824B=1GiB][2^40B=1099511627776B=1TiB]
Note: disk size is measured in MB, GB, or TB, not in MiB, GiB, or TiB.  computer
memory (RAM) is measured in MiB and GiB.
To: LightningIsMyName
Cc: gimp-developer@lists.xcf.berkeley.edu
Sent: Sun, August 29, 2010 1:37:40 AM
Subject: Re: [Gimp-developer] Wish: A better animation system inside GIMP
>scripts and GAP...
>> Olivier Lecarme
>more.
If you are interested in multi-layer animations, the duration and mode of layers
is obviously a layer property. Why not use the layer name for this? It is
Olivier Lecarme
Sent: 2010-10-04 12:24:53 UTC (over 1 year ago)
> want to support, since there are MANY)
> the modern formats.  I believe mplayer can read a lot of these formats, and
> what mplayer does not read, ffmpeg does. ffmpeg even does AVI[MJPEG] which
> is what my camera puts out.
GEGL being a graph based image processing/compositing framework is
lends itself well for building animation based systems as well as
static image things like GIMP. One of the projects that I abandoned
development of and folded into GEGL when GEGL development was
restarted some years back was a combined video sequencing/compositing
system. Some of the examples in the GEGL source tree are also simple
animations driven from C or ruby/python.
GEGL has input nodes and output nodes built on top of the ffmpeg
libraries (quite probably bitrotted, but salvagable). Perhaps similar
nodes should be created along the same pattern as well that use
GStreamer instead.
/Øyvind K.
Welcome!
Lost password?
Not a member? Sign up!
Random tutorials | Latest tutorials
  1. Cool glowing text Cool glowing text 40
  2. Creating 3D icons Creating 3D icons 35
  3. Create an amazing electricity effect on any object! Create an amazing electricity effect on any object! 6
  4. Create the Dragan effect Create the Dragan effect 2
Latest comments
But I just have 1 more prob (bear with me) I am really having troub... (2 days ago in [AVATAR] Become a real Na'Vi using GIMP!)
I got it to work :) I had to close the image and restart it. I thin... (2 days ago in Create cool rifts with translucent lights!)
there was a second and 3rd release of 2.6.12. we included the lates... (2 days ago in Last stable 2.6 release: 2.6.12 has arrived)
Poll
Is GIMP an adequate application for you to create printed graphics like flyers, advertisments etc?
Latest forum activities
Your Ad Here
facts & numbers
gimpusers.com RSS feed
48 identi.ca followers
750 Twitter followers
powered by bitfire it services
