GIMP Compatiblity with gtk+-2.90.x
Forums ► For GIMP developers (read-only) ► GIMP Compatiblity with gtk+-2.90.x
BugByteMan
(over 1 year ago)
- Michael Natterer (over 1 year ago)
Sent: 2010-07-06 21:08:36 UTC (over 1 year ago)
GIMP (git) is not currently compatible with gtk+2.90.x versions (gtk+-3.0).
The first error I ran into is the use of deprecated functions:
CC gimpbrowser.lo
In file included from gimpwidgets.h:75:0,
from gimpbrowser.c:30:
../libgimpwidgets/gimpunitmenu.h:48:3: error: expected specifier-qualifier-list
before 'GtkOptionMenu'
../libgimpwidgets/gimpunitmenu.h:65:3: error: expected specifier-qualifier-list
before 'GtkOptionMenuClass'
make: *** [gimpbrowser.lo] Error 1What are the plans to make GIMP (git) compatible with the gtk+?
-- BugByteMan
Gimp-developer mailing list
Sent: 2010-07-07 00:28:40 UTC (over 1 year ago)
> +-3.0).
> CC gimpbrowser.lo
> specifier-qualifier-list before 'GtkOptionMenu'
> specifier-qualifier-list before 'GtkOptionMenuClass'
> What are the plans to make GIMP (git) compatible with the gtk+?GIMP 2.x is a GTK+ 2.x application,
GIMP 3.x will be a GTK+ 3.x application.We guarantee the same API and ABI compatibility
for our plug-ins as GTK+ does, so we can't move
to GTK+ 2.90 now.After GIMP 2.8 (which will use GTK+ 2.22) is out, we
will move to GTK+ 3.x (and thus GIMP 3.x).Besides, why are you bulding GIMP against GTK+ git
master anyway, GTK+ master is currently not good
for anything but developing GTK+ 3.0 itself, and
porting applications to it. You should stick with
the gtk-2-22 branch if you want bleeding edge of
the GTK+ you are used to.ciao,
--mitch_______________________________________________
