Gimp-developer Digest, Vol 92, Issue 26
Forums ► For GIMP developers (read-only) ► Gimp-developer Digest, Vol 92, Issue 26
mailman.339091.1274886455.1621.gimp-developer@lists.XCF.Berkeley.EDU
Dieki N
(over 1 year ago)
(over 1 year ago)
- Dieki N (over 1 year ago)
(over 1 year ago)
Dieki N
(over 1 year ago)
Sent: 2010-05-26 17:21:15 UTC (over 1 year ago)
> Message: 5
> Date: Wed, 26 May 2010 17:10:03 +0200
> From: Martin Nordholts
> Subject: Re: [Gimp-developer] Patch to improve the brush size keyboard
> shortcuts
> To: gimp-developer@lists.XCF.Berkeley.EDU
> Message-ID:
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> On 05/26/2010 03:05 AM, Dieki N wrote:
> > I've created a patch to improve the behavior of brush size
> > increase\decrease keyboard shortcuts, particularly at small sizes and
> > large sizes.
> Just checking: Have you tried the 'Increase/Decreate Radius Relative'
> keyboard shortcuts?
> / Martin
> My GIMP Blog:
> http://www.chromecode.com/
> "GIMP 2.8 development still under control"
I have now. :)The problem with that shortcut is that it resizes the brush radius (In the
brush options) and thus does not work for bitmap brushes or default brushes.
It's also not mapped to anything by default, probably for those reasons.My patch is for the tool options "brush scale" keyboard shortcut (By default
mapped to "[" and "]") which of course works all brushes._______________________________________________
Gimp-developer mailing list
Sent: 2010-05-28 20:57:21 UTC (over 1 year ago)
> the brush options) and thus does not work for bitmap brushes or
> default brushes. It's also not mapped to anything by default, probably
> for those reasons.
> default mapped to "[" and "]") which of course works all brushes.Why don't we introduce a 'Scale Brush Relatively' action then and change
the default keyboard mapping to use that? Changing the scale step at
arbitrary points, such as done by your patch, makes the 'brush scale'
action unpredictable. It would make more sense to scale the brush
relatively to its current size.Sven
Sent: 2010-05-28 21:07:19 UTC (over 1 year ago)
> > for those reasons.
> Sven
> That does make more sense. I'll get to work on making a patch for that.Dieki
