Problems building git version
Forums ► For GIMP developers (read-only) ► Problems building git version
Emil Assarsson
(almost 2 years ago)
Michael Natterer
Emil Assarsson
Martin Nordholts
- Emil Assarsson (almost 2 years ago)
Martin Nordholts
Emil Assarsson
Michael Natterer
Sent: 2010-03-17 22:49:25 UTC (almost 2 years ago)
I can't build Gimp from the git:
Making all in libgimpwidgets
make[2]: Entering directory `/home/emil/gimp-build/gimp/libgimpwidgets'
CC gimpstock.lo
gimpstock.c:394: error: ‘stock_input_device_22’ undeclared here (not
in a function)
gimpstock.c:521: error: ‘stock_input_device_16’ undeclared here (not
in a function)
gimpstock.c:521: error: initializer element is not constant
gimpstock.c:521: error: (near initialization for
‘gimp_stock_menu_pixbufs[24].inline_data’)
make[2]: *** [gimpstock.lo] Fel 1
make[2]: Leaving directory `/home/emil/gimp-build/gimp/libgimpwidgets'
make[1]: *** [all-recursive] Fel 1
make[1]: Leaving directory `/home/emil/gimp-build/gimp'
make: *** [all] Fel 2Do I need to upgrade xorg or something?
Emil
Gimp-developer mailing list
Sent: 2010-03-18 11:28:40 UTC (almost 2 years ago)
On Wed, 2010-03-17 at 22:49 +0100, Emil Assarsson wrote:
> Hi,
> CC gimpstock.lo
> in a function)
> in a function)
> Do I need to upgrade xorg or something?No, you need to *always* use autogen.sh and *never* configure directly
when you build from git (as opposed to tarball).--mitch
Sent: 2010-03-18 20:12:28 UTC (almost 2 years ago)
Thank you! it worked like a charm...
git pull
./autogen.sh
>> Hi,
>> CC gimpstock.lo
>> in a function)
>> in a function)
> --mitch
Emil
Sent: 2010-03-18 20:14:46 UTC (almost 2 years ago)
On 03/18/2010 08:12 PM, Emil Assarsson wrote:
> make distclean #<--- to clean up the old messIf you want a greater feeling of satisfaction, run
git clean -xdf
instead. Warning: removes all unversioned files
I never run make distclean...
/ Martin
My GIMP Blog:
http://www.chromecode.com/
"Multi-column dock windows and 2.8 schedule"
Sent: 2010-03-18 20:27:15 UTC (almost 2 years ago)
Quite useful :-) Thanks!
>> make distclean #
> git clean -xdf
> / Martin
> My GIMP Blog:
Emil
