Adding ability to reverse curves dialog
ForumsFor GIMP developers (read-only) ► Adding ability to reverse curves dialog
Sent: 2010-03-09 21:51:04 UTC (almost 2 years ago)
On the GIMP-USER list....
On 03/09/2010 03:02 PM, Brendan wrote:
> On Tuesday 09 March 2010, Sven Neumann wrote:
>> On Tue, 2010-03-09 at 14:49 -0500, Jay Smith wrote:
>>> The Color > Curves dialog has the black in the lower left corner
>>> and the white in the upper right corner. This is the opposite of
>>> another program that I also have to use. Is there a way to
>>> reverse this default?
>> GIMP is Free Software. You are given the source code and the right
>> to modify it according to your needs.
> Oh, Sven, how users love your answers.
> To the OP: no, there is no option to switch it. You would have to
> change the source code and recompile.
The above exchange occurred today on the Gimp-User list.
I am posting here for discussion prior to posting an Enhancement
Suggestion on Bugzilla.
For a future version, I wish to propose adding the ability to reverse
the direction of the black/white in the Curves dialog. A toggle button.
Given that Gimp has such a great feature for storing past Curves
adjustments, I am concerned that the toggle state would need to be added
to that information storage.
Does anybody other than me think that it would be a useful feature to
add the ability to reverse the Curves black/white direction?
Thanks.
Jay
Gimp-developer mailing list
Sent: 2010-03-09 22:11:57 UTC (almost 2 years ago)
The reason that I suggested that you do this change to your local copy
of GIMP is that I don't think that this change would be useful for a
large part of our target user base.
Adding this option to the source code will make the code harder to
maintain and will increase the likelihood of bugs being introduced (by
that particular change or at a later point in time). Adding a toggle
button will make the user interface more complex and will degrade the
user experience for most users.
So unless you can persuade us that this feature is in-line with the
product vision that we have for GIMP and that it is indeed important
enough to outweigh the disadvantages that I explained above, we are not
going to consider it.
Sent: 2010-03-09 22:12:39 UTC (almost 2 years ago)
I find it about a useless as a feature as it gets. Standard curve
direction is black bottom left and white top right. If there is a
problem about understanding the curve, that might be made more clear,
but not by switching directions.
Just my personal opinion here tho.
--Alexia
Sent: 2010-03-09 22:30:58 UTC (almost 2 years ago)
Hi Alexia,
I am not sure where the "standard" that you mention comes from. I had
never seen black at bottom left (by default) until I started to use Gimp.
Is there some actual scientific standard underlying that? Or just
majority of programs? Or the programs you have used? Or?
Maybe the programs I have used in the past were backward.
Jay
Sent: 2010-03-09 22:35:23 UTC (almost 2 years ago)
That standard is based on the fact that Ive never seen a curves tool
that is not like that.
This and the fact that this the sane direction of any value axis
covering positive values.
--Alexia
Sent: 2010-03-09 22:39:28 UTC (almost 2 years ago)
On Tue, 09 Mar 2010 16:30:58 -0500
> Gimp.
I would suggest that they were. The "curves" are graphs plotting value
in (x) against value out(y). Traditionally a graph starting at 0 for
both axes would be drawn with the origin in the bottom-left.
This naturally leads to a curves graph where black (0) is in the
bottom-left and white (255/1023/...) is in the top-right.
What programs have you used where this situation was reversed?
Jon
Sent: 2010-03-09 22:47:03 UTC (almost 2 years ago)
On 03/09/2010 04:12 PM, Sven Neumann wrote:
> Hi,
> Sven
The greatest benefit that comes to my mind is that it puts the user in
control and allows the user to align the program to their way of
thinking/working.
However, *if* Alexia is correct and that the "standard" is to do it as
Gimp currently does (black in lower left), then making such a change is
not as useful to most users as it would be to me.
While "putting the user in control" may or may not (?) be part of Gimp's
product vision, I suggest that it should be.
The same can be said for things like having the program remember various
dialog settings the user has changed. (I posted about one of those in
the Gimp-User list today.)
The general arguments you raise such as "code harder to maintain" and
"interface more complex" are all perfectly legitimate and could be said
of virtually any program change. However, they are not a "shield" from
change. Rather, they are a "filter" which must be passed as part of a
cost/benefit analysis.
Jay
Sent: 2010-03-09 22:49:07 UTC (almost 2 years ago)
>> Gimp.
> Jon
Jon,
That is certainly possible.
The one that most comes to mind is Photoshop 5.x.
I have no idea what "modern" Photoshop and successors do.
Jay
Sent: 2010-03-10 03:06:27 UTC (almost 2 years ago)
>>> Gimp.
>> Jon
> Jon,
http://www.adobe.com/designcenter/photoshop/articles/phscs2at_learncurves_02.html
White on the right, Same as GIMP, PSP, etc.
Sent: 2010-03-10 03:15:15 UTC (almost 2 years ago)
>>>> Gimp.
>>> Jon
>> Jon,
Thanks David,
Yep, that's what that picture shows.
BUT... that little double-arrow thingy at the bottom of the curves graph
reverses black/white positions.
It is entirely possible that umpteen years ago when we first installed
Photoshop on Windows 95 that that double arrow got clicked and we have
used it reversed ever since. Or maybe back then white was at the upper
right.
Okay, if the world says black is lower left, we will use it that way.
Thanks.
Case closed.
Jay
Sent: 2010-03-10 09:04:34 UTC (almost 2 years ago)
Indeed, that is exactly what they are. And that's why you need to give
us reasons other than "I would like that feature because it would be
useful for me". Otherwise this change has nothing but costs and will be
rejected.
> graph reverses black/white positions.
Sorry, but the fact that another program has a toggle button for this is
not an argument for adding such a toggle button to GIMP. So is there any
work-flow or use-case for which it would be beneficial to reverse the
direction?
Sent: 2010-03-10 10:43:40 UTC (almost 2 years ago)
> direction?
How about editing in CMYK space, where higher numbers mean greater ink
density? Perhaps this is why Photoshop has this 'flip' feature.
Of course GIMP is luminance only for now (higher numbers mean more
light, not more ink) but this could change in the next few versions.
John
Sent: 2010-03-10 11:21:58 UTC (almost 2 years ago)
2010/3/10 :
>> direction?
Good point, but in this case GIMP can do the necessary invert and flip
for the user, no need for a toggle for that.
/ Martin
Sent: 2010-03-11 18:23:46 UTC (almost 2 years ago)
> for the user
How? :)
Alexandre
Sent: 2010-03-11 18:38:09 UTC (almost 2 years ago)
>> for the user
> How? :)
By knowing that it works on buffers with ink density and not light
intensity. So how would GIMP know that? There are many heuristics that
could be used:
* Was the buffer created with Decompose?
* Is guiguru's CMYK projection/curtain down?
* Is there a CMYK color profile attached somehow?
* What babl format is used?
/ Martin
My GIMP Blog:
http://www.chromecode.com/
"Multi-column dock windows and 2.8 schedule"
Sent: 2010-03-12 09:34:12 UTC (almost 2 years ago)
> could be used:
It's common to decompose even to cmyk (especially when working
with scanned images) and this does not mean that "curves"
should suddenly behave differently, and neither does it mean
that one is working with "ink". E.g. I sometimes do this to
compensate for registration problems that happened when the
image was printed 100 years ago, e.g. by moving the Y layer.
(I could really do with a View filter that showed the recomposed
result, or maybe a layer mode, so that with all layers shown I
got the proper colour appearance)
Either curve-ui-inversion should be under user control with a flip
button, or not happen, I think. Curves going backwards when I
switch windows isn't a nice concept.
Liam
Ankh: irc.sorcery.net irc.gnome.org www.advogato.org
Welcome!
Lost password?
Not a member? Sign up!
Random tutorials | Latest tutorials
  1. Hot Wallpaper with Flames Hot Wallpaper with Flames 52
  2. Creating an abstract chaos explosion Creating an abstract chaos explosion 10
  3. Create a simple Grunge-Stamp! Create a simple Grunge-Stamp! 7
  4. Ashes to ashes, dust to dust. Dissolve text into particles Ashes to ashes, dust to dust. Dissolve text into particles 3
Latest comments
2.6.12 crashes on startup in windows xp. 2.6.11 works fine. (2 days ago in Last stable 2.6 release: 2.6.12 has arrived)
Thank you! You really helped! The tutorial went great for me! Tha... (5 days ago in [AVATAR] Become a real Na'Vi using GIMP!)
maybe you still selected a channel or so? explicitly click a layer ... (5 days ago in Create cool rifts with translucent lights!)
Poll
Is GIMP an adequate application for you to create printed graphics like flyers, advertisments etc?
Latest forum activities
Your Ad Here
facts & numbers
gimpusers.com RSS feed
48 identi.ca followers
749 Twitter followers
powered by bitfire it services
