how to create a window in gimp plugin?
Forums ► For GIMP developers (read-only) ► how to create a window in gimp plugin?
gbstack
(over 2 years ago)
- Adam Turcotte (over 2 years ago)
- Martin Nordholts (over 2 years ago)
(over 2 years ago)
- gbstack (over 2 years ago)
Sent: 2009-07-02 08:01:16 UTC (over 2 years ago)
Hello,everybody!
I want to create a window in gimp plugin,so this is my code(part of the
plugin):/static void run (const gchar *name,
gint nparams,
const GimpParam *param,
gint *nreturn_vals,
GimpParam **return_vals)
static GimpParam values[1];
GimpPDBStatusType status = GIMP_PDB_SUCCESS;
GimpRunMode run_mode;
GtkWidget *window;gtk_init();
/* Setting mandatory output values */
*nreturn_vals = 1;
*return_vals = values;values[0].type = GIMP_PDB_STATUS;
values[0].data.d_status = status;/* Getting run_mode - we won't display a dialog if
* we are in NONINTERACTIVE mode */
run_mode = param[0].data.d_int32;
window = gtk_window_new(GTK_WINDOW_TOPLEVEL);
gtk_window_set_title(GTK_WINDOW(window),"hello");
gtk_widget_show(window);gtk_main();
}/but when I ran the plugin in gimp,it didn't work...
and this is the error message:(hello:12429): GLib-GObject-WARNING **: invalid (NULL) pointer instance
(hello:12429): GLib-GObject-CRITICAL **: g_signal_connect_data:
assertion `G_TYPE_CHECK_INSTANCE (instance)' failed(hello:12429): LibGimp-CRITICAL **: gimp_window_set_transient: assertion
`gimp_ui_initialized' failed(hello:12429): Gtk-WARNING **: Screen for GtkWindow not set; you must
always set
a screen for a GtkWindow before using the window(hello:12429): Gdk-CRITICAL **: gdk_screen_get_default_colormap:
assertion `GDK_IS_SCREEN (screen)' failed(hello:12429): Gdk-CRITICAL **: gdk_colormap_get_visual: assertion
`GDK_IS_COLORMAP (colormap)' failed(hello:12429): Gdk-CRITICAL **: gdk_screen_get_default_colormap:
assertion `GDK_IS_SCREEN (screen)' failed(hello:12429): Gdk-CRITICAL **: gdk_screen_get_root_window: assertion
`GDK_IS_SCREEN (screen)' failed(hello:12429): Gdk-CRITICAL **: gdk_window_new: assertion `GDK_IS_WINDOW
(parent)' failed(hello:12429): Gdk-CRITICAL **:
gdk_window_enable_synchronized_configure: assertion `GDK_IS_WINDOW
(window)' failed(hello:12429): Gdk-CRITICAL **: gdk_window_set_user_data: assertion
`window != NULL' failed(hello:12429): Gtk-CRITICAL **: gtk_style_attach: assertion `window !=
NULL' failed(hello:12429): Gtk-CRITICAL **: gtk_style_set_background: assertion
`GTK_IS_STYLE (style)' failed(hello:12429): Gtk-CRITICAL **: gtk_paint_flat_box: assertion
`GTK_IS_STYLE (style)' failed(hello:12429): Gdk-CRITICAL **: gdk_window_set_accept_focus: assertion
`GDK_IS_WINDOW (window)' failed(hello:12429): Gdk-CRITICAL **: gdk_window_set_focus_on_map: assertion
`GDK_IS_WINDOW (window)' failed(hello:12429): Gdk-CRITICAL **: gdk_window_set_modal_hint: assertion
`GDK_IS_WINDOW (window)' failed(hello:12429): Gtk-CRITICAL **: gtk_window_realize_icon: assertion
`widget->window != NULL' failed(hello:12429): Gtk-WARNING **: Screen for GtkWindow not set; you must
always set
a screen for a GtkWindow before using the window(hello:12429): Gdk-CRITICAL **: gdk_window_set_geometry_hints: assertion
`GDK_IS_WINDOW (window)' failed(hello:12429): Gdk-CRITICAL **: gdk_window_unmaximize: assertion
`GDK_IS_WINDOW (window)' failed(hello:12429): Gdk-CRITICAL **: gdk_window_unstick: assertion
`GDK_IS_WINDOW (window)' failed(hello:12429): Gdk-CRITICAL **: gdk_window_deiconify: assertion
`GDK_IS_WINDOW (window)' failed(hello:12429): Gdk-CRITICAL **: gdk_window_unfullscreen: assertion
`GDK_IS_WINDOW (window)' failed(hello:12429): Gdk-CRITICAL **: gdk_window_set_keep_above: assertion
`GDK_IS_WINDOW (window)' failed(hello:12429): Gdk-CRITICAL **: gdk_window_set_keep_below: assertion
`GDK_IS_WINDOW (window)' failed(hello:12429): Gdk-CRITICAL **: gdk_window_show: assertion
`GDK_IS_WINDOW (window)' failedanyone can tell me how to fix it?
any suggestion is appreciated.
Todong Ma._______________________________________________
Gimp-developer mailing list
Sent: 2009-07-02 17:52:28 UTC (over 2 years ago)
On Thu, Jul 2, 2009 at 2:01 AM, gbstack wrote:
> I want to create a window in gimp pluginI'm not sure if this helps, but when I've created gimp plugins, I've
always used gimp_dialog_new () instead of gtk_window_new ().For an example, take a look at the scale_dialog () method here:
http://gsoc.rivetsforbreakfast.com/gimp/IBFNBQH.cAdam Turcotte
Sent: 2009-07-02 19:56:19 UTC (over 2 years ago)
On 07/02/2009 08:01 AM, gbstack wrote:
> Hello,everybody!
> plugin):
>One way that always works is looking at how other plug-ins does it, for
example:
http://git.gnome.org/cgit/gimp/tree/plug-ins/common/decompose.cLook in/around decompose_dialog()
/ Martin
Sent: 2009-07-02 22:01:23 UTC (over 2 years ago)
On Thu, 2009-07-02 at 14:01 +0800, gbstack wrote:
> Hello,everybody!
> plugin):Please have a look at
http://developer.gimp.org/writing-a-plug-in/1/index.htmlIn particular part III of this tutorial should be helpful.
Sent: 2009-07-03 07:16:00 UTC (over 2 years ago)
thanks for your tutorials,plugin examples and suggestions.now it's fixed,if I use gimp_ui_init instead of gtk_init,I can create a
GtkWindow in gimp plugin now.thank you all! :-)
Todong Ma_______________________________________________
