gegl-gtk 0.0.7 released - 0.1.0 preview
Forums ► For GEGL developers (read-only) ► gegl-gtk 0.0.7 released - 0.1.0 preview
- Jon Nordby (6 months ago)
GIMP 2.8.0 for Mac OS X available! [Update]
GIMP 2.8.0 for Windows is available
Surprise: Working 16-bit mode landing in GIMP!
Sent: 2011-11-20 16:28:55 UTC (6 months ago)
gegl-gtk is an integration library for using GEGL in GTK+ based applications.
gegl-gtk provides a GeglGtkView widget, showing the output of a node in a
GEGL graph. Both GTK+ 2 and GTK+ 3 is supported.
The widget supports translation and scaling, along with autoscaling.GObject Introspection bindings allows it to be used from languages like
Python, Vala, Javascript etc.This release is a preview of the first stable release 0.1.0. Please help test.
Tarball: http://www.jonnor.com/files/gegl-gtk-0.0.7.tar.bz2
Md5sum: 646b2cf05a636ece6d55a9ba7d179361
Git tag: http://git.gnome.org/browse/gegl-gtk/tag/?id=0.0.7Minor things like default arguments might still change, but unless
bugs are found the API is final.gegl-gtk is packaged for Arch Linux, and can be found here:
https://aur.archlinux.org/packages.php?ID=54169
https://aur.archlinux.org/packages.php?ID=54168Jon Nordby - www.jonnor.com
Here I use similar principle to make color image from bw: http://x32.in.ua/?p=897 (but ...Spicing up black/white images
Adding comments to an image (Alt+IEnter, and then "Comments") doesn't work. When I com...Do/Did you have technical Problems with GIMP 2.8.0 or does everything run smoothly?
For everyone having the "procedure entry point" issues, the old zlib1 is definitely the...GIMP 2.8.0 (Windows)
I had this problem too. The cause turned out to be an old copy of zlib1 in my systems f...GIMP 2.8.0 (Windows)
819 @ Twitter
