GEGL + QT, another proposal
Forums ► For GEGL developers (read-only) ► GEGL + QT, another proposal
Jon Nordby
(10 months ago)
(10 months ago)
- Jon Nordby (10 months ago)
Martin Nordholts
(10 months ago)
Jon Nordby
(10 months ago)
Jon Nordby
(10 months ago)
(10 months ago)
Sent: 2011-07-21 16:24:13 UTC (10 months ago)
After some hacking this weekend, we now have a minimally useful
gegl-qt library: https://github.com/jonnor/gegl-qt
Currently it a set of a basic view widgets* showing the output of a
GeglNode. A bit more info can be found in the README.txt file, and
examples showing the usage can be found in the examples/ directory.
Testing, usage and contributions welcomed!Unless there are any objections I propose to do the same as with
gegl-gtk: Put on git.gnome.org, create a gegl-qt component in bugzilla
and add to Jenkins.Martin, this thing uses qmake. For adding to Jenkins is there anything
special I should do? Create a configure script (wrapping qmake), and
add a distcheck target?* One for each of the widget paradigms in Qt4 (QWidget, QGraphicsView
and Qt Quick).Jon Nordby - www.jonnor.com
Sent: 2011-07-21 18:05:11 UTC (10 months ago)
> and add to Jenkins.Even though it uses Qt.. I think the gnome git repository is the most
natural place to stick this convenience library since it is based on
GEGL and all the other GEGL pieces, including a gegl-clutter library
which I added there today are hosted. So unless there are any other
objections I do not see why not./Øyvind K.
-- William Gibson
http://pippin.gimp.org/ http://ffii.org/
Gegl-developer mailing list
Sent: 2011-07-21 18:45:11 UTC (10 months ago)
>> and add to Jenkins.
The purpose of the library is to facilitate the use of GNOME
technology (GEGL), so I personally do not see why it should be a
problem.
The relevant stated pre-requisite for things hosted on git.gnome.org
is "It must use GTK+/GNOME technologies."[1], which it definitely
fulfills.1. https://live.gnome.org/ProjectPrerequisites
Sent: 2011-07-21 19:50:32 UTC (10 months ago)
2011/7/21 Jon Nordby :
> add a distcheck target?Just provide the set of commands used to build gegl-qt after a new git
checkout and I'll take care of the rest.If you want (I encourage you to), create an account on Jenkins so that
I can give you admin privileges so you can configure jobs./ Martin
My GIMP Blog:
http://www.chromecode.com/
"GIMP 2.8 schedule on tasktaste.com"
Sent: 2011-07-21 20:43:37 UTC (10 months ago)
> checkout and I'll take care of the rest.qmake -r
makeIf installing is wanted, "qmake -r
GEGLQT_INSTALL_PREFIX=/custom/prefix" (default prefix is /usr) and
"make install" can be used. In the qmake world, INSTALL_ROOT is
equivalent to DESTDIR, if there is want for such. The buildsystem uses
pkg-config for finding GEGL, of course.
Note: On Fedora and similar, qmake might be qmake-qt4.> If you want (I encourage you to), create an account on Jenkins so that
Done. Username: jonnorJon Nordby - www.jonnor.com
Sent: 2011-07-23 12:04:47 UTC (10 months ago)
I've moved the library to git.gnome.org now:
http://git.gnome.org/browse/gegl-qt/Will fix the gegl-gtk distcheck failure later.
819 @ Twitter
