save 32 bit float as exr file
Forums ► For GEGL developers (read-only) ► save 32 bit float as exr file
Rasmus Hahn
(10 months ago)
Piotr Stanczyk
(10 months ago)
- " (10 months ago)
- " (10 months ago)
Piotr Stanczyk
(10 months ago)
Sent: 2011-07-18 17:13:34 UTC (10 months ago)
i have written an operation for gegl that writes OpenEXR float images, since
i noticed there does not seem to be one already and i could use it. This
version is quite usable within it's limitations. Limitations currently are:- writes only 32 bit linear floating point images.
- only writes Y or RGB images with optional alpha.
- does not make use of OpenEXR specialties like layers, mipmaps
and multichannel.It does support the tiled format; for simplicity, however, tiles are always
square.I would like to see it included in the distribution; for now i have attached
a patch, which creates a new file gegl/operations/external/exr-save.cc and
makes a modification to the Makefile.am to build it. The patch is against
version gegl-0.1.6, but works with the git-version (as of 2011-07-13), too.
Sorry, for not providing a URL, but i do not have one right now.The built operator is named 'gegl:exr-save' and has two properties:
path (string) - the filename to write to
tile (int) - the width of a tile (used for both x and y size);
the default is 0, which means a scanline file is written.Any comments or suggestions for this?
Greetings - Rasmus
Sent: 2011-07-18 17:45:19 UTC (10 months ago)
Thanks for adding ... Any thoughts on adding 16-bit floating point
support? You could then consider using the RGBA interface ...On Mon, Jul 18, 2011 at 10:13 AM, Rasmus Hahn wrote:
> Hi,
> and multichannel.
> square.
> Greetings - Rasmus
> _______________________________________________
> Gegl-developer mailing list
> Gegl-developer@lists.XCF.Berkeley.EDU
> https://lists.XCF.Berkeley.EDU/mailman/listinfo/gegl-developer
Sent: 2011-07-18 20:13:45 UTC (10 months ago)
> version is quite usable within it's limitations. Limitations currently are:Thank you :) I am not sure if the current way the format of the buffer
is determined is the most robust, but it probably works well enough. I
added the op to master and made the coding style more consistent with
the rest of GEGL/GIMP.> I would like to see it included in the distribution; for now i have attached
> Sorry, for not providing a URL, but i do not have one right now.---
Author: Øyvind Kolås
Date: Mon Jul 18 21:08:56 2011 +0100AUTHORS: add Rasmus Hahn
commit 5470164d7a8677d9ea1ea67282650476b4d17aa4
Date: Mon Jul 18 21:08:30 2011 +0100exr-save: normalize coding style
commit d9512a262c845bb59f47ba103c1b7a32790ccf37
Date: Mon Jul 18 20:56:50 2011 +0100exr-save: add new op from Rasmus Hahn
----It would have been slightly nicer if you used git format-patch and
included a commit message for the patch yourself. Thank you :)/Øyvind K.
-- William Gibson
http://pippin.gimp.org/ http://ffii.org/
Sent: 2011-07-18 20:17:10 UTC (10 months ago)
On Mon, Jul 18, 2011 at 6:45 PM, Piotr Stanczyk
> support? You could then consider using the RGBA interface ...The op already supported Y, YA, RGB and RGBA - but all only with 32
bit floating point support. If support for half floats were to be
added this would have to be added to babl, either as an extension or
to the base of babl (the latter probably makes most sense). Looking at
the additional data types added for CIE Lab could act as inspiration.I do however think having support for half-float exr is less important
than 32bit float so this is a great start in itself :)/Øyvind K.
-- William Gibson
819 @ Twitter
