GEGL GObject introspection file
Forums ► For GEGL developers (read-only) ► GEGL GObject introspection file
Sayak
(12 months ago)
- Jon Nordby (12 months ago)
GIMP 2.8.0 for Mac OS X available! [Update]
GIMP 2.8.0 for Windows is available
Surprise: Working 16-bit mode landing in GIMP!
Sent: 2011-06-01 03:57:08 UTC (12 months ago)
Thanks to all, i have successfully compiled GEGL in windows using MSYS/MinGW. I
have tested several C-codes and all are running. Now, in the next step, i need
to use the C-code as a native code and call it using JNI to Android programming.
I have heard of GEGL GObject introspection file at gegl/Gegl-0.1.gir. Please
tell me how to use this file to generate JNI and Java code automatically. by the
way, i didnt find any .gir file in my system...
Sent: 2011-06-01 08:22:36 UTC (12 months ago)
The .gir and .typelib will only be built if you have the required
libraries for introspection available at build time.
Using the .gir file for bindings has very little to do with Gegl. That
is a general GObject introspection topic, and you should use the
GObject introspection communication channels for questions about it.Jon Nordby - www.jonnor.com
Here I use similar principle to make color image from bw: http://x32.in.ua/?p=897 (but ...Spicing up black/white images
Adding comments to an image (Alt+IEnter, and then "Comments") doesn't work. When I com...Do/Did you have technical Problems with GIMP 2.8.0 or does everything run smoothly?
For everyone having the "procedure entry point" issues, the old zlib1 is definitely the...GIMP 2.8.0 (Windows)
I had this problem too. The cause turned out to be an old copy of zlib1 in my systems f...GIMP 2.8.0 (Windows)
819 @ Twitter
