gegl-0.1.2 test failures on IRIX/MIPSpro
ForumsFor GEGL developers (read-only) ► gegl-0.1.2 test failures on IRIX/MIPSpro
Sent: 2010-03-15 13:21:54 UTC (almost 2 years ago)
After building successfully gegl's test-suite fails with the following
output when built on MIPS/IRIX with the platform MIPSpro compilers
(latest release: 7.4.4m):
Making check in gegl
Making check in buffer
make[2]: Nothing to be done for `check'.
Making check in graph
Making check in module
Making check in operation
Making check in process
Making check in property-types
make[2]: Nothing to be done for `check-am'.
Making check in operations
Making check in affine
Making check in core
make check-local
make[3]: Nothing to be done for `check-local'.
Making check in common
Making check in perlin
make[3]: Nothing to be done for `check'.
make check-local
make[4]: Nothing to be done for `check-local'.
Making check in generated
make check-local
Making check in external
Making check in bin
make[1]: Nothing to be done for `check'.
Making check in tools
Making check in examples
Making check in data
Making check in tests
make check-am
make buffer-test
make[4]: `buffer-test' is up to date.
make check-TESTS
36 of 36 tests succesful.
PASS: buffer-tests-results.sh
1 test passed
Making check in compositions
make check-TESTS
make[4]: Entering directory `gegl-0.1.2/tests/compositions'
Failed to open ./reference/clones.png
Failed to open ./reference/downsharptest.png
Failed to open ./reference/downsizetest.png
Failed to open ./reference/downsmoothtest.png
Failed to open ./reference/reflect2.png
Failed to open ./reference/reflect.png
Failed to open ./reference/rotate.png
Failed to open ./reference/simple-scale.png
Failed to open ./reference/upsharptest.png
Failed to open ./reference/upsizetest.png
Failed to open ./reference/upsmoothtest.png
0 of 11 tests succesful.
FAIL: verify-results.sh
1 of 1 test failed
make[4]: *** [check-TESTS] Error 1
make[4]: Leaving directory `gegl-0.1.2/tests/compositions'
make[3]: *** [check-am] Error 2
make[2]: *** [check-recursive] Error 1
make[1]: *** [check-recursive] Error 1
make: *** [check-recursive] Error 1
Instructing make to continue after errors have occurred results in the
following additional output:
make check-TESTS
make[3]: Entering directory `gegl-0.1.2/tests'
** (test-change-processor-rect:31370014): WARNING **: Failed to set
operation type gegl:text, using a passthrough op instead
PASS: test-change-processor-rect
PASS: test-proxynop-processing
PASS: test-color-op
PASS: test-gegl-rectangle
All 4 tests passed
I don't know whether the 'passthrough' warning is significant or not
(although it doesn't sound good), or why the opening of the above files
(which do exist and have reasonable permissions) is failing.
Note that this gegl is built against the most-likely-broken babl I sent
an email about earlier, which complains about non-symmetric transforms.
Cheers,
Stuart
Gegl-developer mailing list
Welcome!
Lost password?
Not a member? Sign up!
Random tutorials | Latest tutorials
  1. Hot Wallpaper with Flames Hot Wallpaper with Flames 52
  2. Creating an abstract chaos explosion Creating an abstract chaos explosion 10
  3. Create a simple Grunge-Stamp! Create a simple Grunge-Stamp! 7
  4. Ashes to ashes, dust to dust. Dissolve text into particles Ashes to ashes, dust to dust. Dissolve text into particles 3
Latest comments
2.6.12 crashes on startup in windows xp. 2.6.11 works fine. (2 days ago in Last stable 2.6 release: 2.6.12 has arrived)
Thank you! You really helped! The tutorial went great for me! Tha... (5 days ago in [AVATAR] Become a real Na'Vi using GIMP!)
maybe you still selected a channel or so? explicitly click a layer ... (5 days ago in Create cool rifts with translucent lights!)
Poll
Is GIMP an adequate application for you to create printed graphics like flyers, advertisments etc?
Latest forum activities
Your Ad Here
facts & numbers
gimpusers.com RSS feed
48 identi.ca followers
749 Twitter followers
powered by bitfire it services
