How to build GEGL with GLIB in a non standard directory?
Forums ► For GEGL developers (read-only) ► How to build GEGL with GLIB in a non standard directory?
hce
(about 2 years ago)
- Martin Nordholts (about 2 years ago)
Sent: 2010-01-09 00:35:58 UTC (about 2 years ago)
I have built all packages source code in /opt directory of my Debian
3.0 box, including glib-2.20.4 in /opt directory. How can I define
glib and other package libraries required in gegl configuration to
build gegl? At the moment I've gollowing errors while I was compiling
gegl-0.1.0 and I could not find how to specify glib to run gegl
configure.checking for GLIB - version >= 2.16.1... no
*** Could not run GLIB test program, checking why...
*** The test program failed to compile or link. See the file config.log for the
*** exact error that occured. This usually means GLIB is incorrectly installed.
configure: error:
*** GLIB 2.16.1 or better is required. The latest version of
*** GLIB is always available from ftp://ftp.gtk.org/.Thank you.
Kind regards,
Jupiter
Gegl-developer mailing list
Sent: 2010-01-09 08:42:52 UTC (about 2 years ago)
hce wrote:
> Hi,
> build gegl?You need to set PKG_CONFIG_PATH and LD_LIBRARY_PATH (but only at
configure-time).You might find this post helpful:
http://www.chromecode.com/2009/12/best-way-to-keep-up-with-gimp-from-git_26.html/ Martin
My GIMP Blog:
"Best way to keep up with GIMP from git"
