Patch for rectangle func and GeglRectangle initialization in tests/buffer/buffer-test.c
ForumsFor GEGL developers (read-only) ► Patch for rectangle func and GeglRectangle initialization in tests/buffer/buffer-test.c
Sent: 2009-11-29 17:31:05 UTC (about 2 years ago)
1. The void rectangle function in tests/buffer/buffer-test.c should be
static void to match the prototype.
2. You cannot initialize rect when you declare it in rectangle() unless
you assume a C99 compiler.
Patch for both issues attached.
albert chin (china@thewrittenword.com)
Index: tests/buffer/buffer-test.c
--- tests/buffer/buffer-test.c.orig 2009-11-29 16:20:15.964770878 +0000
+++ tests/buffer/buffer-test.c 2009-11-29 16:28:32.408518645 +0000
@@ -270,15 +270,20 @@
-void rectangle (GeglBuffer *buffer,
- gint x,
- gint y,
- gint width,
- gint height,
- gfloat value)
+static void rectangle (GeglBuffer *buffer,
+ gint x,
+ gint y,
+ gint width,
+ gint height,
+ gfloat value)
GeglBuffer *sub_buf;
- GeglRectangle rect={x,y,width,height};
+ GeglRectangle rect;
+ rect.x = x;
+ rect.y = y;
+ rect.width = width;
+ rect.height = height;
sub_buf = gegl_buffer_create_sub_buffer (buffer, &rect);
fill (sub_buf, value);
Gegl-developer mailing list
Welcome!
Lost password?
Not a member? Sign up!
Random tutorials | Latest tutorials
  1. Hot Wallpaper with Flames Hot Wallpaper with Flames 52
  2. Creating an abstract chaos explosion Creating an abstract chaos explosion 10
  3. Create a simple Grunge-Stamp! Create a simple Grunge-Stamp! 7
  4. Ashes to ashes, dust to dust. Dissolve text into particles Ashes to ashes, dust to dust. Dissolve text into particles 3
Latest comments
2.6.12 crashes on startup in windows xp. 2.6.11 works fine. (2 days ago in Last stable 2.6 release: 2.6.12 has arrived)
Thank you! You really helped! The tutorial went great for me! Tha... (5 days ago in [AVATAR] Become a real Na'Vi using GIMP!)
maybe you still selected a channel or so? explicitly click a layer ... (5 days ago in Create cool rifts with translucent lights!)
Poll
Is GIMP an adequate application for you to create printed graphics like flyers, advertisments etc?
Latest forum activities
Your Ad Here
facts & numbers
gimpusers.com RSS feed
48 identi.ca followers
749 Twitter followers
powered by bitfire it services
