Perf tools evaluation and proposal
Forums ► For GEGL developers (read-only) ► Perf tools evaluation and proposal
Henrik Akesson
(over 2 years ago)
Boudewijn Rempt
(over 2 years ago)
Henrik Akesson
(over 2 years ago)
jcupitt@gmail.com
(over 2 years ago)
Henrik Akesson
(over 2 years ago)
- jcupitt@gmail.com (over 2 years ago)
Henrik Akesson
(over 2 years ago)
jcupitt@gmail.com
(over 2 years ago)
Henrik Akesson
(over 2 years ago)
Boudewijn Rempt
(over 2 years ago)
Sent: 2009-06-17 11:37:24 UTC (over 2 years ago)
here's the promised evaluation of the current profiling tools and a proposal.
Henrik
TOOLS
Valgrind - retained
Oprofile - retained
gprof, sprof - obsoleted by oprofile
ltrace, ptrace - not capable of profiling dynamically loaded objects (dlopen-ed)
GEGL instrumentation - same functionality is achieved by the below proposition.Further info: http://sites.google.com/site/computerresearcher/profiling-tools/
PART ONE - VALGRIND - Where the time is spent
################################################################################Current tools are capable of producing an abundance of profiling data.
Callgrind (with Cachegrind activated) will produce 13 different
measurements for every line of code that has been executed during the
program run:
1 on how many times the line has been executed
8 on cache use
4 on branchingRunning callgrind on a command line gegl program that runs
gaussian-blur produces profiling data for 149 different objects (89 of
which are gegl operations that get loaded)!!!NOTE: A serious limitation of Valgrind is that it can only count
events, it cannot tell you how much time things take (such as cache
miss or execution time for an instruction). This is because it heavily
modifies the code before running it, and therefore renders any time
measurements useless.I propose to implement a tool that allows the user to (step 1) select
the data he is interested in and (step 2) presents the results in a
easy-to-understand way.
Step 1 - SELECTION - user workflow:
1a) Select the libraries of interest
1b) Select the entry/exit function (normally the main function), i.e.
only data measured inside this function (including calls to other
functions) is displayed
1c) Hotpath elaboration. I.e. display and selection of the code
execution path to display. (TBD)Step 2 - EVALUATION - workflow:
2a) Code annotation. I.e. display the above selected code with measurements
2b) Trend displayStep 3 - MANAGEMENT - workflow:
3a) Adding new data (cmd line and web)
3b) Adding new evaluation scenarios (web)
3c) Listing data
3d) Deleting data
3e) Listing scenarios
3f) Deleting scenarios
3g) Adding scenarios################################################################################
PART TWO - OPROFILE - What the processor is doing
################################################################################An important limitation of the processor's performance counters is
that from a choice of about 100, there are only 2-8, depending on
processor model and mark, that can be used in the same moment. There
has been some attempts by some researchers to multiplex them, but this
requires modification of kernel code and thus is not accessible for
the ordinary mortal developer.I propose to:
a) By repeatedly running the test/performance case assemble all the
important data into the database
b) Possibly there will be a need to use statistics in order to have
reliable data (i.e. determine which distribution and use this during
data collection) TBD.
c) Add groups of annotation data to the point 2a. Basically groups
such as "L1 Cache use", "L2 Cache use", "Vector extensions" etc...Normally the data should be stored internally in the same format as
for valgrind. This means that only an import tool needs to be written
in order to add oprofile data.################################################################################
IMPLEMENTATION DETAILS
################################################################################I propose a web-based implementation using jRuby and Ruby on the Rails
together with a sql database (could potentially be an object database
= db4o).For the code annotation, I propose to use the existing subversion
repository for retreiving the code to be annotated and GNU source
highlight._______________________________________________
Gegl-developer mailing list
Sent: 2009-06-17 11:52:43 UTC (over 2 years ago)
> easy-to-understand way.Doesn't kcachegrind provide all of this for you?
Boudewijn
Sent: 2009-06-17 12:44:48 UTC (over 2 years ago)
The main differences of my solution compared to KCachegrind are:
I would use a database approach allowing to display performance
history. I.e. in the case of a drop in performance, a developer would
be able to localise it to a certain commit. Also useful for comparing
the performance of two different solutions during development.The aggregation of counter, IMHO is very important for understanding
what the processor is doing. It is a very difficult task, and just
having data from 2-8 counters is like providing only a small window on
a big complex image.I think that you could summarize kcachegrind as a tool that shows you
all the data whereas the approach I propose is to show as little data
as possible in order to localise performance issues and when found
showing the full image of what the processor is doing.IMHO KCachegrind is not easy to use nor understand (ex: what does
"Distance 6-11 (6)" mean? etc...)My solution is web based.
I believe that this is enough of differences to justify a new tool. Is
it to you?Henrik
2009/6/17 Boudewijn Rempt :
> Boudewijn
Sent: 2009-06-20 23:15:30 UTC (over 2 years ago)
Hi Henrik,
2009/6/17 Henrik Akesson :
> it to you?OK, though I hope the project is not becoming too ambitious. One of
the reasons we all liked your original proposal so much was that it
seemed focused and clearly achievable. I would be slightly concerned
that you are maybe looking too much at the presentation of results and
not enough on getting the numbers to start with.How about as a next step setting up a small test suite, a series of
automated measurements, and a simple reporting generator? Leave the
fancy web interface until the basic tests and measurements are
working. This would also give you something concrete to show at the
mid-term evaluation.John
Sent: 2009-06-22 11:38:51 UTC (over 2 years ago)
John,
Hmm, I'm not sure I've expressed myself clearly...
Currently, I have a simple ruby test harness and a guassian-blur test
that I use to generate test data with Valgrind. For the valgrind part,
I plan on using all the measurements callgrind + cachegrind can
provide. Oprofile is much more complicated (as there's a choice of
roughly 80 measurements and because it's based on statistical
sampling).This is why I focus on valgrind for mid-term. Paying attention to your
concern, I propose to start with a very simple web-interface (using
text when possible instead of fancy graphics etc...) and then working
towards improving it.However, I will not have the time to set up a test suite before
mid-term. Therefore I propose to start that ASAP after the mid-term.I intend to produce a fully functional suite based on Valgrind before
starting with oprofile, as I estimate the latter as the "high-risk"
part of the project. Like that I can guarantee you a working tool-set
using valgrind and hopefully also something that can provide the
"bells-and-whistles" of oprofile.Does this seem reasonable to you?
Henrik
2009/6/20 :
> Hi Henrik,
>> it to you?
> John
Sent: 2009-06-22 12:00:55 UTC (over 2 years ago)
Hi again Henrik,
2009/6/22 Henrik Akesson :
> that I use to generate test data with Valgrind.Ah, OK, sorry, I'd only seen the report, I didn't realise you had
something concrete going already. I was worried there might not be
much to see at mid-term.Your proposal sounds good to me, well done.
> mid-term. Therefore I propose to start that ASAP after the mid-term.On the performance tests, a senario I've used in the past is described here:
http://www.vips.ecs.soton.ac.uk/index.php?title=Benchmarks
It's derived from a real application which took high-resolution master
images off a server and generated files for printing on a large-format
inkjet. It might be a bit fiddly to implement. A much simpler version
is here:http://www.vips.ecs.soton.ac.uk/index.php?title=Speed_and_Memory_Use
This is just: load, crop, shrink, sharpen, save. It's not very
demanding, but it is very easy to implement, and typical of
applications like Picasa or F-Spot. It might be helpful I guess.I'm sure the gimp list could suggest an application benchmark that
would be typical of GEGL use in Gimp.John
